Some3 Posted April 12, 2022 Report Share Posted April 12, 2022 Hi I'm planing to use a v350 plc with HSC input that read the frequency of a encoder. This will tell me the rotation speed of the work piece. I would like to use this information to controll a PTO for a stepper motor. I need to specify a ration betwen the encoder speed and the speed of the stepper motor(direction does not meter) I'm making a electronic gearbox. The proces is slow therfore the cycle time of the plc will be ok. Is it possible to chenge the speed reference during move. I was planing to use the motor in jog mode but in excaples the PTO move block is alweys activated with a risng edge. will the block: 1. work if I call in continuous? 2. will the block accept the new speed reference? 3. if it accetes the new reference how will it transition to the new speed? I don't want the motor to stop driting the transition to a new speed of rotation. thanke you Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted April 12, 2022 MVP 2021 Report Share Posted April 12, 2022 Please use Example from folder C:\Program Files (x86)\Unitronics\Unitronics VisiLogic_C\Examples\Version 900\Project examples\HSC_ HSO V120_Stepper_motor_with_Acc_and_Dec.vlp Quote Link to comment Share on other sites More sharing options...
