Sergio Ramos Posted April 14, 2022 Report Share Posted April 14, 2022 Hello everyone! I am doing a new project on a samba sm43 jr20. I am using an ammonia sensor to read data, and would like to display it on my PLC. This sensor in particular uses the protocol IES-CAN ISO 11898. Does visilogic support this protocol? If it does, in which communication would it fall under (CANopen,J1939,Unican etc.)? Any comments are appreciated. Thank you! Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted April 14, 2022 MVP 2021 Report Share Posted April 14, 2022 Please post sensor model number or pdf manual for this sensor. Quote Link to comment Share on other sites More sharing options...
Sergio Ramos Posted April 14, 2022 Author Report Share Posted April 14, 2022 21 minutes ago, kratmel said: Please post sensor model number or pdf manual for this sensor. Sure thing! Here it is. Also I think it could be done with the protocol of CANlayer2, although I'm not sure. I'll try to look for examples. NH3 sensor manual.pdf Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted April 14, 2022 MVP 2021 Report Share Posted April 14, 2022 I do not use this type of protocol https://www.ti.com/lit/an/sloa101b/sloa101b.pdf The main problem - find message format for this sensor type in standard hex form. 1 Quote Link to comment Share on other sites More sharing options...
