Guest tumminello calogero Posted June 6 Report Share Posted June 6 buon giorno michiamo Calogero ho appena iniziato a studiare come autodidatta a programmare con visilogic ho un plc unitronics v700 con modulo v200_18_e4xb ho un inverter c200_024 control techniques commander vorrei comandare una pompa 380v facendo un semplice programma con comandi start stop aumenta velocita' diminuisce velocita' e in una finestara vedere la velocita che va oppure la percentuale mi potete dare una mano con un semplice programma dove io poi studiero grazie vi lascio la mia email tumminellocalogero@gmail.com Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted June 6 MVP 2021 Report Share Posted June 6 Such a frequency converter does not have a built-in communication port (To control via a digital communication network, the port must be purchased separately). Therefore, the PLC project requires that you connect the PLC to the inverter with wires according to the diagram (minimum wire needed pointed on pic). That is, you need to connect a common wire 0V (51 or 1). Connect the PLC outputs to the discrete inverter inputs (11,12). And also connect the analog output of the PLC to the analog input of the inverter (2). If you already have a scheme - describe it. If not, draw it as you need and post it here on the forum. We will help you with the next steps in programming. Unfortunately, there is no point in creating a project for you without this homework. Quote Link to comment Share on other sites More sharing options...
