JohnnyB Posted September 3, 2011 Report Share Posted September 3, 2011 Hi I follow steps as described in pdf instrution (Enhanced Vision PLC WebServer 14/5/09), but the page that i create don´t start. If i download the vlp file from Web server example my page start. Basic i create in ladder : SB2 - Card Init - Plc Name - Socket init (01 - tcp-raw). In Card init i config IP for my network and gateway. The problem is not connectivity because the page work on vlp from example. It´s very strange. Any suggestions please? Thanks Link to comment Share on other sites More sharing options...
JohnnyB Posted September 5, 2011 Author Report Share Posted September 5, 2011 Guys I think I was wrong the obvious. In the file .VLP must have functions specific for function the data transfer, because it the "own" program don´t start. When i said, i config only Card Init, Socket init, PLC name and an counter using SB 1sec pulse. If problem is that, what i need for making my "own advanced web server". I ask it because in example use more that 300 MI´s, maybe is possible reduce. Do you confirm my "suspicion" :-)? Have a great day Link to comment Share on other sites More sharing options...
Jas Posted September 6, 2011 Report Share Posted September 6, 2011 If you wish to use the enhanced webserver hosted off of the SD card, it is a requirement to use the template project supplied. There are several locked subroutines that provide the functionality and proper data transfer between the SD card for HTML. Link to comment Share on other sites More sharing options...
