Unistream with faulty USB ports how can i upgrade?
I have a unistream 15" US-156-B10 and i managed to have both usb ports damaged when i was having a usb to serial converter to a printer.
Now that i need to upgrade the panel to the new firmware i am not able to use the usb ports .
What are my options? I tried the SD card but it cannot find the files to proceed with the update
Please contact support@unitronics.com  with quastion about upgrade via SD.
I do not recommend to repair PLC but qualified electronic engineer can check USB ports power chip MIC2026-1 (output pin 5 and  8 ) and two components on main board.
I found one Unistream PLC with this elements damaged ,  replace it and succesfully repair both USB ports.
