Aiman Posted August 30, 2022 Report Share Posted August 30, 2022 Hello and good day, Currently I have finished creating a plugin inside a robot that sends messages/robot status/program status/error messages as ASCII to net assistant. the net assistant acts a server TCP host for the messages to be received. My question is, how do I send the data to HMI PLC instead and select which messages go to which part? and how do I send a prepared data string as a message to the robot? Quote Link to comment Share on other sites More sharing options...
MVP 2021 kratmel Posted August 30, 2022 MVP 2021 Report Share Posted August 30, 2022 Moved... Please post robot model # if it is standard robot. What PLC you want to use? Quote Link to comment Share on other sites More sharing options...
