Schaft encoder on V350
Hi,
I need to read 4 shaft encoder in my project. I am using V350-J-R34 and IO-D16A3_TO16  but   after I got it I become aware that   IO-D16A3_TO16 can not read shaft encoder with HSC  inputs. Is there any IO epansion module besides EXF-RC15 which can read  one aditional shaft encoder in connection with V350-J-R34.
9 hours ago, ivica said:
.... no IO expansion module  on V350 that can read shaft encoder.
V350 J R34 has 3 Encoder input.... But if you need one more encoder input  EXF-RC15 must be used.
I try to generate all possible option for add encoder input without EXF-RC15
10 hours ago, kratmel said:
URB TCP + URD0200E(or  URD0200D) + V100SET2 installed to V350.
But i do not test this new hardware on Vision PLC.
Maybe using secondary V130 Slave PLC with HSC +2хV100SET2 installed to V350 and V130 and modbus TCP can be faster in delivery and even cheaper.
