Tomasz Posted September 7, 2011 Report Share Posted September 7, 2011 Send Email.vlp Hi, from some time I try to send e-mail from V570 via internet. No success so far. I try example from forum "Send Email.vlp" and always "not connected". I use unit V570 with Vision 9.3.0 build 0 Questions: 1) Is any one was able to make it work ? Is this future works at all ? 2) What exactly happen when press "connect" ? What PLC do ? Send any thing to Internet like ping ? telnet ? !!! I check my mail server IP, type, connect to server via telnet, obtain respond 220 , etc. From PC works. I would like to ask anyone (Unitronics ?) to help with this issue, please. I still would like to believe it could work. If more information is needed please ask I will provide it. best regards Tomasz Quote Link to comment Share on other sites More sharing options...
Jas Posted September 8, 2011 Report Share Posted September 8, 2011 When you are trying to connect to your corporate mail server from the PLC, is the PLC plugged into the local corporate ethernet network? Quote Link to comment Share on other sites More sharing options...
Tomasz Posted September 9, 2011 Author Report Share Posted September 9, 2011 When you are trying to connect to your corporate mail server from the PLC, is the PLC plugged into the local corporate ethernet network? It is a bit different. I am plug at home to my router which is plug to provider modem. Tomasz Quote Link to comment Share on other sites More sharing options...
