Magnien Posted November 19, 2022 Report Share Posted November 19, 2022 hello, I want to create a program on a V350 j ra 22 to modify the speed of a pump using a pressure sensor 4-20ma . I indicate a pressure to be reached on the screen. my pump speed is changed by the analog output 0-10v Quote Link to comment Share on other sites More sharing options...
MVP 2021 Flex727 Posted November 19, 2022 MVP 2021 Report Share Posted November 19, 2022 Sounds like you need a PID loop. There are examples that came with your VisiLogic installation. Quote Link to comment Share on other sites More sharing options...
