I do this frequently. Have a 'master" timer that you set on your HMI, then perform in ladder "Load Timer/Counter Preset" (under the "Store" menu) to an ML. Then perform "Store Timer/Counter Preset" to all the timers you want to set from the master timer. Easy peasy.
I'm not sure exactly what you're asking, but you can set any number of timers you wish using the same ML that you loaded from the master timer. You could easily load from master and set all 13 timers in the same ladder rung.
