connect with EATON DC1
  • MVP 2022
communication-manual-for-variable-frequency-drives-variable-speed-starters-da1-dc1-de0-mn040018en.pdf
Please read p.12 for correct setup DC1. Connection parameter can not be changed. You must connect DI1 for operate drive via MODBUS.
Please use PC modbus software and Usb-RS485 converter for test connection before try to use Unistream PLC.
