Unistream Touch Screen Calibration Always Failing
Dear Support team,
I have the Unistream US5-B10-B1 OPLC. The factory default touch screen calibration is bad, hence I used the Touch Screen Calibration command from the Uniapps menu. It usually worked well, however on this peace of hardware after touching all the 5 points, it writes "Calibration Failed" and recommends to do it again or restart...I have tried it sereral times with the same result. Any recommendations?
Thank  you,
Best regards,
Martin Sirovy.
This forum does not contain a "Support Team". It is a user forum staffed by volunteer users, though a few Unitronics employees make an appearance from time-to-time. Unitronics support can be reached at support@unitronics.com. For a hardware issue under warranty you might also consider contacting your distributor for return or replacement.
Regarding your question, I haven't encountered that particular issue before but perhaps someone here has. Good luck.
