jesuscardenas Posted February 16 Report Share Posted February 16 Hello, I had an error with this module. Suddenly it stopped generating the analog outputs, and the RUN led blinked. It is worth mentioning that I am using 3 inputs and 2 outputs (all 0-10v), one of the inputs is 0-8v with 16-bit resolution. Is the problem related to this? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted February 16 MVP 2021 Report Share Posted February 16 6 minutes ago, jesuscardenas said: Suddenly it stopped generating the analog outputs This is usually a bad sign. Was this working before and for how long? Joe T. Quote Link to comment Share on other sites More sharing options...
jesuscardenas Posted February 16 Author Report Share Posted February 16 Before I only used 1 single input, since I added the two inputs, the problem started. (1 week ago) Quote Link to comment Share on other sites More sharing options...
jesuscardenas Posted February 16 Author Report Share Posted February 16 it has a year of purchased Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted February 16 MVP 2021 Report Share Posted February 16 That sounds like a grounding problem. Is your DC power supply 0V terminal connected to earth ground? Joe T. Quote Link to comment Share on other sites More sharing options...
