Jhav Posted February 17 Report Share Posted February 17 All i have questions about finding flow rate from a flow meter? it can read 462 pulses per gallon with a Range of .26-16 gallons per minute or 120.12-7292 pulses per minute i want to display gallons per minute . I have MI-3 as a Frequencey measurment at 1000ms or 1 sec . so i took MI-3x60 that is pulses in 1 second x 60 to get its rate per minute then linearized it in 0-7292 for 0-16 gpm. is this a good way to find flow rate? Quote Link to comment Share on other sites More sharing options...
MVP 2021 Ausman Posted February 17 MVP 2021 Report Share Posted February 17 Have a look at this post and the rest of the topic: https://forum.unitronics.com/topic/4599-totalizer-to-gpm/?do=findComment&comment=17077 cheers, Aus Quote Link to comment Share on other sites More sharing options...
