USD file error
Trying to view a saved trend on my laptop using and it keeps telling me it can't open the USD file.
There is no USD file on the sd card just the UTR file.
Any ideas what is causing this?
SD Card Manager
Unable to open Trends USD File.
The file might not contain any samples, which may result this error.
OK
  • 7 months later...
2 hours ago, Saragani said:
It  converts the UTR file into USD file. It appears that the UTR file doesn't contain any data.
I did work out what was happening.
There was data there, but due to the way the save trend function had been programmed some segments were empty. Didn't cause any issues viewing data on the device just on the laptop.
