john Posted September 8, 2010 Report Share Posted September 8, 2010 I'm new to programming in Visilogic and am working with the V130. I'm sure I must have overlooked a way to show min and max process variable bounds (or limits) on a bar graph or a meter. The only method I've come up with is to manually place lines over the graphic. But this isn't viable because the display will be used for different objects (in my case fans and pressure sensors) each of which will have uniquely defined min and max range limits as well as min and max process boundaries. Overlaying mulitple bar graphs would solve this, but Visilogic apparently (as far as I can determine) will not allow this. Get anyone suggest how to incorporate process boundaries into these graphic elements? John Quote Link to comment Share on other sites More sharing options...
HigHTech Posted September 10, 2010 Report Share Posted September 10, 2010 This is the way you limit the values. If you right click the bar graph then you can select the properties window and define the width and height of your bar. Quote Link to comment Share on other sites More sharing options...
john Posted September 10, 2010 Author Report Share Posted September 10, 2010 Thanks, but apparently I didn't express myself well enough. The measurement limits of a variable represented in a bar chart (as you pointed out) or a meter graphic are not the same as process boundaries (aka upper and lower control limits in SPC lingo). Some common domestic examples are 1) an auto tachometer with a 'redline', and 2) water pressure gage at home with upper and lower boundaries marked in red. Industrial applications employ a wide range of sensors and other measurements to track varaibles that can (and often do) exceed the desired operating range. I would have thought that this would be a standard feature in a simple bar or meter graphic. Quote Link to comment Share on other sites More sharing options...
jweav2223 Posted September 12, 2010 Report Share Posted September 12, 2010 My experience is that they are one and the same. If a tachometer shows 0-10 on the gauge it doesnt mean an actual measurement cannot be above 10. It's the same as what is described in the Help section that was posted. You're setting the minimum and maxium (0-10) that can be displayed. Doesnt mean an actual measurement cannot be above that. The minimum and maximum of actual measurement would set up in the ladder logic. Quote Link to comment Share on other sites More sharing options...
Phil Salkie Posted September 12, 2010 Report Share Posted September 12, 2010 It'd be fiddly, but could you use the "Draw Line" function block in ladder logic to draw in an upper and lower process boundary line whenever the screen is displayed? Quote Link to comment Share on other sites More sharing options...
john Posted September 14, 2010 Author Report Share Posted September 14, 2010 Phil, You're suggestion was great. It works very well. Thanks. John Quote Link to comment Share on other sites More sharing options...
