Cannot find "Data sample to Excel" output file on UniStream Data converter
Hello I am trying to use unistream data converter to convert data sample to excel, but when i try to add it in input i can't find it, and when i try to convert as PDF I find it, and i don't understand where is the problem.
  • NoamM changed the title to Cannot find "Data sample to Excel" output file on UniStream Data converter
If no "Output folder" was selected, then the output folder is the same as the selecting input folder.
You can select an different output folder if you check the "Choose Excel output files to different folder", and then you can click on the browse button in the output folder and select a different one.
  • 2 months later...
If UniStream Data Converter continues to be problematic for CRM data enrichment, you might consider using alternative software for data conversion to Excel. There are several third-party data conversion tools available that can perform this task reliably. Additionally, exploring open-source options can be a cost-effective approach, as many community-supported projects offer robust Excel conversion capabilities. Furthermore, reaching out to your IT department or seeking recommendations from colleagues who have faced similar challenges could provide valuable insights into alternative solutions. Ultimately, finding the right tool to streamline your CRM data enrichment and data conversion process can significantly enhance your workflow and productivity.
