curtharrington1 Posted June 14 Report Share Posted June 14 Is it possible to configure scope trace triggers to start/stop the trace? This would be handy for troubleshooting. Quote Link to comment Share on other sites More sharing options...
AlexUT Posted June 15 Report Share Posted June 15 Can you give as an example what you wish to trace and why this cannot be solved other way? Quote Link to comment Share on other sites More sharing options...
curtharrington1 Posted June 15 Author Report Share Posted June 15 Example: I want to start a trace on a tag used for the analog output to a VFD and the analog input for the motor feedback but I only want trace to be active when the tag for the motor enable (digital output) is true. B&R's automation studio has trace trigger configuration settings for trigger on, trigger off, on delay and off delay which are very helpful for solo troubleshooting of complex systems. Quote Link to comment Share on other sites More sharing options...
