Interact Posted June 22, 2023 Report Share Posted June 22, 2023 When looking at the 'How Timers work' page of the U90 Ladder help, the term 'Timer Reset' is mentioned. I am however unable to figure out how I would use this. How do I reset a timer (that is running)? Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted June 22, 2023 MVP 2023 Report Share Posted June 22, 2023 Two ways to reset a timer - 1. Remove power from it's coil 2. Use a Reset coil -(R) assigned to the timer's address. If the timer is enabled and running it will reset its accumulator to 0. Joe T. 1 Link to comment Share on other sites More sharing options...
Interact Posted June 23, 2023 Author Report Share Posted June 23, 2023 13 hours ago, Joe Tauser said: 1. Remove power from it's coil I can build a network in U90 Ladder that would accomplish this for one cycle, but it seems clumbersome... 13 hours ago, Joe Tauser said: 2. Use a Reset coil -(R) assigned to the timer's address. If the timer is enabled and running it will reset its accumulator to 0. U90 Ladder doesn't allow me to use a Reset coil on T(imers). Only on MB, O and SB... or is there a trick I am missing? Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted June 23, 2023 MVP 2023 Report Share Posted June 23, 2023 8 hours ago, Interact said: U90 Ladder doesn't allow me to use a Reset coil on T(imers). You are correct. Sorry about that - I was thinking Visilogic. U90 was the original software for the Unitronics M90 series introduced back in 2000. It's written in VB6. There are many things about it that are cumbersome compared to Visilogic and Unilogic. I don't use Jazz PLCs on anything because the Visions are so much easier to implement. I wrote a ton of code in U90 many years ago when the M91s were all we had. With U90 you just have to do what you need to do with a limited function set. Joe T. 1 Link to comment Share on other sites More sharing options...
