garydreppert Posted June 23, 2023 Report Share Posted June 23, 2023 I have some actuators I am controlling with a vision 700 over modbus. When I read the holding registers for the position data the data is being brought in as signed 2s compliment numbers. Does anyone know why this is and how to bring it is as base 10? If i read the same registers with the program MODBUS POLL the data reads correctly with that program which leads me to believe it is something in how Visilogic converts the data. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted June 23, 2023 MVP 2023 Report Share Posted June 23, 2023 That should totally not be happening. What is the make and model of the actuators? What are your port parameters? Can you upload the portion of your program that handles Modbus communication? Joe T. Quote Link to comment Share on other sites More sharing options...
Fernando Castro Posted June 26, 2023 Report Share Posted June 26, 2023 On 6/23/2023 at 9:44 AM, garydreppert said: I have some actuators I am controlling with a vision 700 over modbus. When I read the holding registers for the position data the data is being brought in as signed 2s compliment numbers. Does anyone know why this is and how to bring it is as base 10? If i read the same registers with the program MODBUS POLL the data reads correctly with that program which leads me to believe it is something in how Visilogic converts the data. Are you sure that is actually what is going on, based on my own experience using Modbus on Unitronics devices and without giving it much more thought It sounds like it may be the endianness. are you sure that you are not getting the Bytes in a reversed order? if that the case the easiest way to fix it is to use swap bytes function block Quote Link to comment Share on other sites More sharing options...
