word to double word
Version software: 1.33.236
Hello,
I communicate with the frequency converter and the PLC via modbus. I have an absolute sensor connected directly to a frequency converter.
I read the parameters from the frequency converter. I need to read the value of the current revolutions (rev). I can read this using two parameters:
PAR543 - HighWord Actual Position
PAR544 - Actual LowWord position
It is a word ( int16 ) value. How do I combine them into a double word so that it shows me a real value, comparable to the revolutions shown in the frequency converter.
Thank you
ciao
considering that you have to have a variable like UINT32 or INT32 called "revolutions" ...i think that the faster way is ... revolutions = PAR543 * 65536...then  revolutions = revolutions + PAR544 ... so use the FB "multiplication" then the FB "addition".
