MELDAW Posted August 29 Report Share Posted August 29 Hello I have USC-B5-TA30 and i was trying to erase everything and do a factory reset, can i get help on this please? Thank you Quote Link to comment Share on other sites More sharing options...
DanT Posted August 29 Report Share Posted August 29 Hi; If you can communicate with the PLC ( Etherent or USB) The create a BLANK or Minimum Program ( Ladder and HMI) On HMI I just do a Text Message and a Clock In Ladder I do nothing Set up the Model info, and the Com's PLC Communications Physical - IP Address Information Panel IP is important Compile and Save the program then Download This will overwrite everything - erase the old program and its setupand install the new program with new program settings. If you cannot communicate with the PLC, then you need an ACTION file to "kick" it. Create a dummy program as per above and save it. UniLogic, Tools - Icon Ribbon- USB ActionFiles Creator ( you will need a USB Key Follow the steps Data - uncheck All Logs - uncheck All Updates -- You decide Communication -- Write new parpameters into the Panel IP date CPU and DNScan be blank at the moment VNC Passwords -- You decide PLC Password -- Use Unitronics factroy default password Save Follow steps to load onto the USB, then plug into the PLC and power down the PLC and power back up Action file will do its thing. Then ping the IP Address and go online -- UniLogic and VNC DanT Quote Link to comment Share on other sites More sharing options...
MELDAW Posted August 30 Author Report Share Posted August 30 Thank you DanT for your reply, so that's gonna erase all the Data, it's not gonna do a factory reset right? Quote Link to comment Share on other sites More sharing options...
DanT Posted August 30 Report Share Posted August 30 Hi; I consider "erase all the Data," as close to a factory reset as you(we) are going to get. When the PLC's come from the factory they usually have a demo program installed in them. We can upgrade or downgrade the OS in the PLC,and install our own Unilogic created programs - that is as far as " the creators " will allow us to go. DanT Quote Link to comment Share on other sites More sharing options...
