Árni Posted August 31 Report Share Posted August 31 Hello I have a unistream us5-b5-ta30 that I'm trying to download to. The PLC had a program on it when I started tinkering with it. I updated the firmware as Unilogic said that was necessary. After that I was able to download a program once to the PLC. Now I am not able to do anything. Every time I try to connect to the PLC in any way it gets stuck on "verifying PLC's password" window. Then after a few seconds the window disappears and nothing happens. I have tried to download an empty program over both USB and ethernet and also tried to "restore PLC password" on the PLC itself. I am at a loss as to what I should do next. Any ideas on how to fix this? Quote Link to comment Share on other sites More sharing options...
DanT Posted September 1 Report Share Posted September 1 Hi Contact support@unitronics.com for assistance Some questons: Did you set up any passowrds in the program? Did you set up any communications parameters in the program? What were these? If possible, you can upload your program for someone on the forum to review.. Forum Moderators and contributors are not Unitronics Support Staff. We are volunteers -- programmers helping programmers. DanT Quote Link to comment Share on other sites More sharing options...
curtharrington1 Posted September 20 Report Share Posted September 20 Try this: load a blank project with the new firmware onto the PLC make a blank project with firmware 1.32 and generate the application and firmware files to a DOC (USB stick) insert USB stick into PLC Go to UniApps Go to Upgrades check the "Forced" checkbox and tap "Upgrade Firmware" update application when firmware update is complete Now create blank application and new firmware files on a DOC Update the PLC's firmware then user application You should now be able to load the desired application with new firmware onto the PLC Quote Link to comment Share on other sites More sharing options...
