jamie y Posted October 2 Report Share Posted October 2 hi there , I'm very new to this so forgive my lack of knowledge i have a vision 350 with no local io, i have a exa2x , io-d18-io4 i have a problem i cant work out, probably a very easy solution i have programed a simple on of switch on the hmi and the ladder, the problem i am having is the relay output wont stay on ,it cycles/flashes realy fast when i activate it is there somthing i should be doing ,thank you Quote Link to comment Share on other sites More sharing options...
jamie y Posted October 2 Author Report Share Posted October 2 Quote Link to comment Share on other sites More sharing options...
MVP 2022 Ausman Posted October 2 MVP 2022 Report Share Posted October 2 Hi Jamie, please read the "Getting Started" topic in the Help files, with particular attention to "Ladder Net' which is a sub heading at the bottom of "Ladder Editor". This will better explain what is going on with your existing ladder construction, and the entire Topic is worthy of a full read for your learning curve. As are all the Help files. cheers, Aus Quote Link to comment Share on other sites More sharing options...
