cuongvcs Posted October 11 Report Share Posted October 11 Dear, all. I started new position in this company and have issued with Visilogix V820 loss password. The old eng did not handover for me the info so I can access Visilogic get the program for backup. can you pls advise me on how I can fix this issue? THank you. Quote Link to comment Share on other sites More sharing options...
MVP 2022 Ausman Posted October 11 MVP 2022 Report Share Posted October 11 Without the password you are in trouble. However, was the Visilogic programming done using a company computer that still exists? If so, the actual project might still be in the computer, and you will then have a copy. Check the name of the project in the PLC by using Info mode to try and match it up to any remaining projects in the computer. Use the Help file in Visilogic to find out how to access Info mode. But Info mode might also have a non-standard password, it all depends on what the original programmer did. Also check whether there is a project copy on the mini SD card if one is fitted in the PLC. Quote Link to comment Share on other sites More sharing options...
cuongvcs Posted October 12 Author Report Share Posted October 12 Dear friend. Thank you for your info. but the old engineer did no handover me anything. I have checked the company PC but no have the software for Unitronics software. Thanks. Quote Link to comment Share on other sites More sharing options...
