Dominic Posted September 30, 2011 Report Share Posted September 30, 2011 I have a customer that downloaded the latest version of Visilogic on a PC running Windows XP SP3. When he tries to open it the screen shows the "Visilogic" splash display as if it is going to open then an error comes up stating that the distributor should be contacted. He then uninstalled the current version and went back to the previous version - same problem. Any ideas? Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted October 4, 2011 Report Share Posted October 4, 2011 Hello Did VisiLogic was worked before properly? if not, please perform Windows Update You can also try to reinstall VisiLogic as below and check if the problem remains: Backup your application files. Uninstall VisiLogic. Erase the “Unitronics” folder from- C:\Program Files Erase the “Unitronics” folder from- C:\Program Files\Common Files. Install VisiLogic again. Please let us know if it helped. Quote Link to comment Share on other sites More sharing options...
Walkerok Posted October 5, 2011 Report Share Posted October 5, 2011 Re-check your UAC settings. I have now had my UAC setting reset from off to on when installing new software (not visilogic) or automatic windows updates. The last occurence of this was just yesterday. Thanks Keith Quote Link to comment Share on other sites More sharing options...
