Paul Augood Posted November 13 Report Share Posted November 13 I am having occasional problems connecting with Remote Operator. What is going on when I get the error "No connection could be made because the target machine actively refused it xxx.xxx.xxx.xxx:20256 (where that IP would be in the xxx.xxx....)? Typically our units are still sending out emails when this occurs but we cant connect. This has been resolved but simply unplugging and plugging the ethernet cable back in but our systems are quite remote and unmanned. Could this physical action be reproduced through programming - re-initializing the ethernet port periodically or some other action? Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 13 Report Share Posted November 13 Are you connecting to the same port that is being used for sending the email? If not, what's the relation to sending email? Is Closing Remote Operator and Starting it again solves the problem? Quote Link to comment Share on other sites More sharing options...
Paul Augood Posted November 14 Author Report Share Posted November 14 Email goes out on a different port - different socket set up in the PLC. I mention it because it kept working (email could go out) but remote operator was giving the message I previously noted. I've had that message before when someone else has been connected but in this situation it continued indefinitely and was only fixed by unplugging and plugging in the ethernet cable. previously. Socket 0 TCP master (port 20258) for SMTP (email) Socket 1 TCP RAW slave (port 80) for web server Socket 2 TCP slave (port 20256) for programming Socket 3 UDP RAW slave (port 20000) for DNS resolver Socket 4 TCP slave (port 20257) for remote access Yes have closed and opened remote operator many time - no change in behaviour form these two PLC (same programs on 50+ others). Quote Link to comment Share on other sites More sharing options...
Saragani Posted November 22 Report Share Posted November 22 OK, Please contact our support team, so they will open a ticket on this issue, so it can be addressed. As far as I understand, the issue is not Remote Operator, but the PLC, that might be too busy for receiving the connection from the PC. Quote Link to comment Share on other sites More sharing options...
