ashish Posted October 4, 2011 Report Share Posted October 4, 2011 i am using this PLC in my hydraulic machine since the last 3-4 yrs. recently, since the last 8-10 days i m facing this problem that one particular output doesnt fire at times ( machine is in a closed loop system) i changed the relay that fires the hydraulic solenoid, SMPS that fires hydraulic solenoid, solenoid valve but cant figure out the problem. can somebody advise me whether there is a problem with the PLC ? Quote Link to comment Share on other sites More sharing options...
Walkerok Posted October 5, 2011 Report Share Posted October 5, 2011 You did not give very much inoformation, but given what you said it is probably not a programing or processor problem of the PLC. If the relay is question fires correctly sometimes and not other times then I would be suspecting wiring has come loose somewhere in the system or a solder joint or connector has developed a vibration related failure (check that all terminals and wires are tight throughout the entire panel). There is a lot that can happen over several years. It is also possible that over time there has been a solder joint inside the PLC that has developed a crack and would cause an intermittend firing of the relay, if so you will have to go inside the PLC and re-solder the connections (check them all under a magnifying glass). If you are unable to check this or perform the re-solder of affected connections then you possibly would need to install a replacement PLC. Keith Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted October 6, 2011 MVP 2021 Report Share Posted October 6, 2011 It is very possible that the contacts of the PLC's relay have become pitted and intermittent, especially if you have an inductive load such as a solenoid connected without an RC snubber across it to absorb the electrical spike that is created when the solenoid is released. If you have a spare output try changing your program to use it and move the wire to the solenoid. Joe T. Quote Link to comment Share on other sites More sharing options...
