Vicente Posted October 6, 2011 Report Share Posted October 6, 2011 I have the V120-22-R1 connected to a GSM. Everything works seemingly well, meaning through the FB, and receives SMS sending SMS without problems. My problem starts when I want to pass the SMS to (MI). Active bit (SB) 199, Store 1000 to (SI) 199 and when I receive a message, is stored in (MI) 500 and the bit (SB) 198 that is not activated a message has arrived. I changed the address in (SI) 199 and always saves it in half the value store. Help please if possible send the file, please Show me where. Riego SMS.vlp Quote Link to comment Share on other sites More sharing options...
Ofir Posted October 6, 2011 Report Share Posted October 6, 2011 Hi, If you check the value in SI199 in online mode, does it contain the right value? Which OS version are you using? Please make sure you are using the latest OS. Quote Link to comment Share on other sites More sharing options...
Vicente Posted October 7, 2011 Author Report Share Posted October 7, 2011 Hello SI 199 in online mode is #1000 and the version is OS 5.04(28) Thank. Hi, If you check the value in SI199 in online mode, does it contain the right value? Which OS version are you using? Please make sure you are using the latest OS. Quote Link to comment Share on other sites More sharing options...
Ofir Posted October 9, 2011 Report Share Posted October 9, 2011 Hi, I checked your application and faced te same problem. I passed this issue to our R&D and will let you know when it will be fixed. Meantime please check the option to use MB2 (SMS scan) to recognize when SMS arrives. Quote Link to comment Share on other sites More sharing options...
Vicente Posted October 10, 2011 Author Report Share Posted October 10, 2011 Ok, I hope it is resolved soon. thanks Quote Link to comment Share on other sites More sharing options...
