Nick. Posted December 31, 2023 Report Share Posted December 31, 2023 Can anyone tell me if you can use can open and EX RC1 on the same can bus? if i install the EX RC1 and not the encoder it works fine and the other way if i remove the EX RC1 and install the encoder it works fine but when i install both of them nether one works I'm not sure if I'm doing something wrong or if you can't use the same can bus for this application? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted January 2 MVP 2023 Report Share Posted January 2 The EX-RC1 used the UniCan protocol. The CANbus port can't run two protocols at the same time. Joe T. Quote Link to comment Share on other sites More sharing options...
