ricardo r Posted January 9 Report Share Posted January 9 Saludos, requiero de su ayuda, estoy programando dos ejes X y Y con la funcion pto me reconoce el canal CH0 realizo movimiento en este eje pero el CH1 no me opera, PTO set profile status set =2 , pto mov status en =3,. este plc funciona para mover 2 ejes? Quote Link to comment Share on other sites More sharing options...
ricardo r Posted January 9 Author Report Share Posted January 9 1 minute ago, ricardo r said: Saludos, requiero de su ayuda, estoy programando dos ejes X y Y con la funcion pto me reconoce el canal CH0 realizo movimiento en este eje pero el CH1 no me opera, PTO set profile status set =2 , pto mov status en =3,. este plc funciona para mover 2 ejes? estoy utiizando plc V130 33 tr34 1 minute ago, ricardo r said: Quote Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted January 9 MVP 2023 Report Share Posted January 9 Please read Help topic and find PTO function error code. Note error codes is different for different PTO FB. Main problem with PTO - correct configuration. Please select correct Unit and Pulses per Unit numbers. Some combination do not work - play with different numbers and different stepper driver divider (2,4,16,32,64 ...ect). It is good if you try to use the same for both channel for test. Also check Ranges, if it is not in correct ranges - no move possible. Note the minimum and maximum ranges for your motion profile. Range Minimum Maximum 1 5 Hz 15 kHz 2 10 Hz 20 kHz 3 305 Hz 133 kHz 4 610 Hz 200 kHz If it possible post your project with PTO configuration to this topic. Quote Link to comment Share on other sites More sharing options...
