micapp Posted June 22, 2014 Report Share Posted June 22, 2014 13Type mismatch See enclosed screendump Quote Link to comment Share on other sites More sharing options...
s.pratt Posted June 23, 2014 Report Share Posted June 23, 2014 When did this error occur? And is it repeatable? Quote Link to comment Share on other sites More sharing options...
micapp Posted June 28, 2014 Author Report Share Posted June 28, 2014 Sorry, late answer. I do not know if I can repeat it. It happened when I quitted Visilogic accidently without giving arguments to the Block. The program was running on Win7 and I used V9.7.0 Visilogic. Quote Link to comment Share on other sites More sharing options...
Eyal Koren Posted June 29, 2014 Report Share Posted June 29, 2014 Sorry, late answer. I do not know if I can repeat it. It happened when I quitted Visilogic accidently without giving arguments to the Block. The program was running on Win7 and I used V9.7.0 Visilogic. This is a known issue with the SMS Send FB in Visilogic 9.7.0. Please install the latest version (9.7.7) from the following link: http://www.unitronics.com/downloads/support/visilogic/VisiLogicSetup_9_7_Build_07.exe Quote Link to comment Share on other sites More sharing options...
RBC Posted July 1, 2014 Report Share Posted July 1, 2014 Hi. If you run the vision software not in administrator mode it gives same problem. I've set mine up now to run as adminstrator always and no more errors like that. Hopes it helps. Quote Link to comment Share on other sites More sharing options...
