Andrew_Spencer_Brennan
Arduino Mega to a Unistream HMI/PLC via MODBUS
Good day All
Im wondering if someone will be able to assist me with the following.
we have a few in house built machinery that runs off Arduino Controllers. We needing to link it up to a Unistream HMI to Display the Data. I know it can be done via Modbus.
Im just needing some help with the initial Modbus from Arduino to Unistream setup
Please Assist where you can
Hi Andrew,
exist many arduino library to use modbus RTU or TCP protocol..both master and slave...then how do the sketch depends on which library you will choose.
each library include examples and someone also a manual...pay attention that Arduino MEGA doesn't has a native RS485 or ethernet port then you will need some extra board (usually cheap).
Dear,
Do you have news about this development?
I also have the need to be able to communicate arduino with PLC Unistream. Tried some modbus TCP / IP libraries, but had no success.
Thanks in advance for your answers.
Setting up the first communication between two devices can sometimes be tricky.
Upload your UniStream program so we can see how your Modbus is configured in it.
