kpetro07 Posted July 8, 2019 Report Share Posted July 8, 2019 Hello all, We have created a small program with REMOTE IO using US5-B10-B1 OS 1.26.51 and we connected IO modules on a URB TCP. Everything works perfectly but if you switch off URB-TCP and switch back on, then CPU cannot find the REMOTE IO (even if we restart the CPU). The only way to find it is to download the program again. We have tried both ways setting the IP for URB-TCP (dip switch and BOOTP) but the problem still remains. We created a program with the same configurations with US10 and we do not have this problem. Any suggestion ? Thanks. Quote Link to comment Share on other sites More sharing options...
Cam Posted October 11, 2019 Report Share Posted October 11, 2019 Maybe a little late but, What modules are on the URB?? I had the same issue with power distribution modules connected to a URB, removing them(in the program and on the din rail) solved the issue. You can still use them they just cannot be conned in to the URB IO they have to be separate. You can also now update the most recent version of UniLogic. Quote Link to comment Share on other sites More sharing options...
