Change plc into u 90 ladder
Hi;
The JAZZ 10 Programs will work in the JZ20 PLC's of the same Model -- like    -R16.
Basically you just have to change the Model Number of the PLC.
Open the original Program, save it under a NEW NAME, then   change the Hardware and save  the program.
Going from a JZ10-11-R16  to a JZ20-R31 :
    Open the JZ10-11-R16 Program.
    Save the program under a NEW NAME.
   Change the Hardware to  JZ20-R31, and Save.
        Now the program has the extra I/O of the R31.
  Modify the new program to suit the application.
  One thing to also do, is when changing and testing programs, SAVE the Program with a New Name -- like an INDEX Number
until the program is complete.  This way, you can backtrack if necessary.
DanT
