Lost 0 Report post Posted November 14 Downloaded u90 6.6.46 Unable to edit/ modify programs/applications. operands when selected go solid black does not open edit box. What am i doing wrong???? windows 10 Tried ver ....36 as well same result. Help please. Quote Share this post Link to post Share on other sites
Ausman 138 Report post Posted November 16 Did you install using Right click/Run as Admin, and also check that the U90Ladder.exe, once installed, is set to Run as Admin in Compatibility? If you did not do this, uninstall and start again. cheers, Aus Quote Share this post Link to post Share on other sites
Lost 0 Report post Posted November 21 On 11/16/2019 at 10:06 PM, Ausman said: Did you install using Right click/Run as Admin, and also check that the U90Ladder.exe, once installed, is set to Run as Admin in Compatibility? If you did not do this, uninstall and start again. cheers, Aus Ahhhhh, that seems to have done the trick, many thanks. Quote Share this post Link to post Share on other sites
Ausman 138 Report post Posted November 22 @Saragani, @Cara Bereck Levy Dear S & C, Wondering why this issue seems to be cropping up again in both Vision and U90 land? I thought it had been changed so that Install as Admin and run as admin were now done automatically. cheers, Aus Quote Share this post Link to post Share on other sites
Cara Bereck Levy 109 Report post Posted November 25 @Ausman, both do run as Admin...but somehow, in the wonderful world of WinDoze....this issue comes up sometimes, but not often enough of consistently enough to be able to trouble shoot. Quote Share this post Link to post Share on other sites
