t0r3r0s Posted December 5, 2019 Report Share Posted December 5, 2019 Greeatings . Can someone help me , i cant connect my pc and v700 plc whit TCP/IP protocol. I see tutorial and configurate all but same problem cant connect. Can someone help me ? Quote Link to comment Share on other sites More sharing options...
DanT Posted December 5, 2019 Report Share Posted December 5, 2019 Hi; Is the Ethernet Cable Plugged into the Ethernet Port ? and are the LED's Flashing for connectivity? The Expansion port uses a RJ45 Connector also, and is often confused with the Ethernet port. Check the PLC using INFO Mode ( Password 1111) Ethernet Upper lines show Ethernet IP and current status Middle allows you to view and set parameters - IP, Sockets Press Monitor to see if any data is reaching the PLC ( selectable by the port ) Are the PLC and PC on the same network? Check the address of the PC. Can you PING the PLC IP Address from the PC and get a reply? DanT Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 5, 2019 MVP 2023 Report Share Posted December 5, 2019 Socket 1 defaults to Port 20256. Unless you are using more than one socket, leave out the Socket Initialization so that you don't inadvertently have more than one socket assigned to the same port number. In addition to the great suggestions by @DanT, use a crossover cable if you aren't using an ethernet hub or switch. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 5, 2019 MVP 2023 Report Share Posted December 5, 2019 Oh, I see that you are initializing the ethernet continuously (MB 102 direct contact). Don't do that. Use SB 2 to initialize. Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted December 5, 2019 Author Report Share Posted December 5, 2019 3 hours ago, DanT said: Hi; Is the Ethernet Cable Plugged into the Ethernet Port ? and are the LED's Flashing for connectivity? The Expansion port uses a RJ45 Connector also, and is often confused with the Ethernet port. Check the PLC using INFO Mode ( Password 1111) Ethernet Upper lines show Ethernet IP and current status Middle allows you to view and set parameters - IP, Sockets Press Monitor to see if any data is reaching the PLC ( selectable by the port ) Are the PLC and PC on the same network? Check the address of the PC. Can you PING the PLC IP Address from the PC and get a reply? DanT Greeatings. Thank you for answer , on my question . ethernet cable is plugged in and flashing is ok , in cmd when i try ping my adress i dont loss any package . Its work , but when I try on visilogic i have error 210 Quote Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 5, 2019 MVP 2023 Report Share Posted December 5, 2019 3 hours ago, Flex727 said: you are initializing the ethernet continuously (MB 102 direct contact). Don't do that. Use SB 2 to initialize. Allow me to repeat. Quote Link to comment Share on other sites More sharing options...
DanT Posted December 5, 2019 Report Share Posted December 5, 2019 Hi; Good Catch Flex, Brain Missed that MB part, SB2 is a one shot on POWER UP Only- First Scan thru. If you want to re-initialize the setup , do the re-init with a -|P|- in the same net, in parallel with the SB2 . DanT Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted December 6, 2019 Author Report Share Posted December 6, 2019 17 hours ago, DanT said: Hi; Good Catch Flex, Brain Missed that MB part, SB2 is a one shot on POWER UP Only- First Scan thru. If you want to re-initialize the setup , do the re-init with a -|P|- in the same net, in parallel with the SB2 . DanT Hi; I have one more problem I cant connect to my remote operator . I have this error . Have you some idea ? Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 6, 2019 MVP 2023 Report Share Posted December 6, 2019 1 hour ago, t0r3r0s said: I have one more problem I cant connect to my remote operator . Did you fix the problem with MB 102? Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted December 6, 2019 Author Report Share Posted December 6, 2019 2 hours ago, Flex727 said: Did you fix the problem with MB 102? Yes I can download with tcp protocol , but i cant connect to remote operator and xdata . I use V700 use socket 0, pot 20256, ip 198.168.1.50 , Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 6, 2019 MVP 2023 Report Share Posted December 6, 2019 Are you using the same computer for both VisiLogic and Remote Operator? If so, they would be using the exact same pathway and if one works, the other should too, but they both can't connect to the same port at the same time. If not, then make sure the Remote Operator computer (or phone) is on the same subnet as the PLC. What I find is that my router hands out addresses to wired and wireless (wi-fi) with different subnets. Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted December 6, 2019 Author Report Share Posted December 6, 2019 36 minutes ago, Flex727 said: Are you using the same computer for both VisiLogic and Remote Operator? If so, they would be using the exact same pathway and if one works, the other should too, but they both can't connect to the same port at the same time. If not, then make sure the Remote Operator computer (or phone) is on the same subnet as the PLC. What I find is that my router hands out addresses to wired and wireless (wi-fi) with different subnets. I have a new problem, I tried with another laptop, to try the remote operator, however the same problem is just that now I can't even load the program over Ethernet. I try with static ip but same problem , i try to change ip but same Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 6, 2019 MVP 2023 Report Share Posted December 6, 2019 It would be helpful if you addressed the troubleshooting comments when you respond. No one can help you if we don't know your situation. @DanT was kind enough to type all this out. Please let us know that you've gone through each of these on the other laptop that you're now having a problem with. On 12/5/2019 at 10:19 AM, DanT said: Is the Ethernet Cable Plugged into the Ethernet Port ? and are the LED's Flashing for connectivity? The Expansion port uses a RJ45 Connector also, and is often confused with the Ethernet port. Check the PLC using INFO Mode ( Password 1111) Ethernet Upper lines show Ethernet IP and current status Middle allows you to view and set parameters - IP, Sockets Press Monitor to see if any data is reaching the PLC ( selectable by the port ) Are the PLC and PC on the same network? Check the address of the PC. Can you PING the PLC IP Address from the PC and get a reply? Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted December 6, 2019 Author Report Share Posted December 6, 2019 20 minutes ago, Flex727 said: It would be helpful if you addressed the troubleshooting comments when you respond. No one can help you if we don't know your situation. @DanT was kind enough to type all this out. Please let us know that you've gone through each of these on the other laptop that you're now having a problem with. Now when i ping i loss all package Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 6, 2019 MVP 2023 Report Share Posted December 6, 2019 Maybe I wasn't clear. If you want help, you need to address every item that DanT mentioned - not just the last one. Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted December 6, 2019 Author Report Share Posted December 6, 2019 13 minutes ago, Flex727 said: Maybe I wasn't clear. If you want help, you need to address every item that DanT mentioned - not just the last one. Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted December 6, 2019 MVP 2023 Report Share Posted December 6, 2019 You have your laptop set to the same IP address as the PLC. That won't work. Quote Link to comment Share on other sites More sharing options...
t0r3r0s Posted December 6, 2019 Author Report Share Posted December 6, 2019 43 minutes ago, Flex727 said: You have your laptop set to the same IP address as the PLC. That won't work. I see now, thank you for your help now remote operator work , thank you Quote Link to comment Share on other sites More sharing options...
