Akram Posted February 21 Report Share Posted February 21 Hello, I am trying to connect my unitronics automate to my PC via the ethernet cable. The remote access software failed to find a connection. I am don't know also how to get the ip adress of the automate to enter it. Can anyone help me please. Thanks a lot! Quote Link to comment Share on other sites More sharing options...
MVP 2023 Flex727 Posted February 21 MVP 2023 Report Share Posted February 21 You can find the IP Address in INFO Mode (see the Help file for more information). However, if this is a new PLC that does not have a program in it, you are better off connecting with a USB cable until you get a program downloaded that has Ethernet initialization and IP Address assignment. Quote Link to comment Share on other sites More sharing options...
DanT Posted February 21 Report Share Posted February 21 Hi; If connecting via Ethernet, you also need the PLC Name and if the PLC was programmed using VisiLogic 9.9.00 - the security passwords. Can you Ping the PLC Addess sucessfully? DanT Quote Link to comment Share on other sites More sharing options...
