Diogenis Posted October 23, 2011 Report Share Posted October 23, 2011 Hi I have 2 weeks to deal with model Jazz And my purpose is to put another 120 itself, and then networking to watch from afar. And I found the following problem. We can draw percentages percent but do not know how. example. One machine is plugged in, 1 hour, but its output is only 45 minutes. The measurement is done in secont. So we 2700/3600 = 0.75 × 100 = 75% was the performance of this who was handling. How can you visualize it;;;; Sorry for my English, I have given you to understand! Thank you. Quote Link to comment Share on other sites More sharing options...
Emil Posted October 23, 2011 Report Share Posted October 23, 2011 Easiest way - divide 2700 by 36 only. Common soluiton - myltiply first 2700 by 100 and then divide by 3600. Use the special function "Factor". Quote Link to comment Share on other sites More sharing options...
Diogenis Posted October 23, 2011 Author Report Share Posted October 23, 2011 Thank emil. And a second question. I have a measurement. Where should the counter greater than 32000 can reach up to 999,999 thousand pulses overall. The math I do is: Spins a shaft / 391 1 revolution = 1 pulse for 1 min = 240 pulse and 1 hour 240 X 60 = 14400 Imagine the number to 8 hours. In those 8 hours I need to know the number of revolutions made by the axis to calculate the production of the machine in action. ( Meters / 8 Hours ) thanks, all Quote Link to comment Share on other sites More sharing options...
MVP 2022 Joe Tauser Posted October 24, 2011 MVP 2022 Report Share Posted October 24, 2011 Use two MI's - one to track the count to 1,000 and then increment a second one and reset the first. Example: MI 1 will contain the thousands and MI 0 will contain the value less than 1000. You can create two variables and put them next to each other on the Jazz display. Joe T. Quote Link to comment Share on other sites More sharing options...
