montania Posted October 25, 2011 Report Share Posted October 25, 2011 I use the V570 and had permanent display hangers. I could fix the problem with a touch delays. The hanger is still happening now in the keypad. One problem is also the multiple entries in the keypad by the fast processor. Question: What may by the problem? Can I install a touch delay for the keypad? How is it possible? montania Quote Link to comment Share on other sites More sharing options...
Damian Posted October 25, 2011 Report Share Posted October 25, 2011 A little hard to understand your problem. Just a guess, are you using transitions to call your screens and functions? It will be easier if you post your code. Quote Link to comment Share on other sites More sharing options...
montania Posted October 25, 2011 Author Report Share Posted October 25, 2011 If I use the keypad, then I have hangers (the Display blocked). If I touch, nothing works. Then I have to calibration the screen, then it working again. this error happens very often. I mean the simple and the complex keypad. I do not need a ladder code, it is firmware. The second problem is the multiple entries on the keypad. Nobody has this problem??? a programmable greeting Quote Link to comment Share on other sites More sharing options...
MVP 2022 Joe Tauser Posted October 26, 2011 MVP 2022 Report Share Posted October 26, 2011 This sounds like a hardware problem. Do you have another V570 to try? Joe T. Quote Link to comment Share on other sites More sharing options...
