sgull Posted November 2, 2011 Report Share Posted November 2, 2011 Hi I am working on a project where a V1040 monitors a process. It is possible that the screen will not be used for a number of consecutive days, with some static information on the screen. Is the screen susceptable to "burn in"? Should I set up a screen saver? Is it possible to turn off the display and get it to "wake up" once touched? Thanks Denis Quote Link to comment Share on other sites More sharing options...
Admout Posted November 2, 2011 Report Share Posted November 2, 2011 Hi friend, There is a link below about training examples. You can find Screensaver example in Day1 folder. It will help you... http://forum.unitronics.com/index.php?/files/file/17-quincy-training-examples-2011/ Quote Link to comment Share on other sites More sharing options...
sgull Posted November 3, 2011 Author Report Share Posted November 3, 2011 Admout Thank you for that. Regards Denis Quote Link to comment Share on other sites More sharing options...
PeterFukt Posted January 3, 2017 Report Share Posted January 3, 2017 Hello, I used the screen saver code from the example with the Samba SM35-J-TA22. The problem is that when the screen is touched and the last page is called and I touched an area with a button on the last called page, that button gets pressed. I want a screen saver that does not activate any buttons when the screen is touched and the screen "wakes up". Is there any easy way to do that? Quote Link to comment Share on other sites More sharing options...
PeterFukt Posted January 3, 2017 Report Share Posted January 3, 2017 The code I used from the example is that when the timer stops, I call an empty HMI. The empty HMI calls a subroutine "on load" that set backlight to 0. The empty HMI calls a subroutine "while displaying"that load last HMI on touch. The empty HMI calls a subroutine "on unload" that sets backlight to 100. But when I touch the screen, I can accidentally press a button on last showed HMI which can be bad for the process running. I need a solution for this if possible. Quote Link to comment Share on other sites More sharing options...
PeterFukt Posted January 3, 2017 Report Share Posted January 3, 2017 I think I solved it by doing like below. Quote Link to comment Share on other sites More sharing options...
Isakovic Posted January 4, 2017 Report Share Posted January 4, 2017 On 2.11.2011. at 8:33 AM, sgull said: Is the screen susceptable to "burn in"? So, is it? I haven't seen any manufacturer that practices screen savers and didn't think much about it. Quote Link to comment Share on other sites More sharing options...
