oferyosef Posted September 5 Report Share Posted September 5 hi is it possible to use v350 with canbus v100-17-can or v100-s-can communicating to siemens s7-1200 ? i need the siemens s7-1200 read few tags from the unitronics v350 via canbus i use the other ports to read data from other instruments. is there any example ? thanks V100-17-CAN,V100-S-CAN Link to comment Share on other sites More sharing options...
MVP 2023 Joe Tauser Posted September 5 MVP 2023 Report Share Posted September 5 I Googled "S7-1200 Protocols" and found it supports CANOPen. So the answer to your question is yes. But I personally can't tell you how. Search the forum for CANOpen posts for some ideas on how to make it work. Joe T. Link to comment Share on other sites More sharing options...
oferyosef Posted September 8 Author Report Share Posted September 8 thanks the card v100-17-can can be use to communicate to s7-1200 ? or it only connect to other unitronics plc ? Link to comment Share on other sites More sharing options...
MVP 2023 kratmel Posted September 8 MVP 2023 Report Share Posted September 8 The V350 PLC together with the expansion card v100-17-can supports the standard CANopen protocol, some Unitronics PLC to PLC protocol ect. In general, the PLC provides for the implementation of CANopen network management - i.e. starting network devices, managing their status, transmitting PDOs, receiving RPDOs and sending SDOs. That is, it is assumed that the PLC is actually the master of the network. I can claim that these actions are successfully performed by the PLC, I have implemented and tested it. However, I did not conduct experiments with the connection of the CANopen network to another PLC - in your case Simatic 1200, which in my opinion also involves work with external devices for which it should actually also be a master. Theoretically, master-to-master work is possible, but its implementation can be difficult without appropriate experience and additional equipment. Please send question to support@unitronics.com for details Link to comment Share on other sites More sharing options...
