Kerry Posted January 9, 2012 Report Share Posted January 9, 2012 I have problems connecting to the Vision when using Visual Basic. When the PC is connecting to the Vision through Visilogic, you can notice the Baud Rates changing at the bottom of the screen. When it gets the right settings, it connects. During the process, you will see 'send break signal'. Is this something that we can use to help connect through the Visual Basic? What is it? Usually it connects right after you see it. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted January 19, 2012 MVP 2021 Report Share Posted January 19, 2012 This is a customer of mine. Can one of the Creators reveal the command sequence Visilogic uses to initialize communications? We'd like to be able to implement this into a VB routine. Joe T. Quote Link to comment Share on other sites More sharing options...
