PCSControls Posted March 21, 2012 Report Share Posted March 21, 2012 I've got a V570 and when I install the SD card it does not get recognized by the controller. I formatted it using the SD Card Suite, Tools Formatter without problem. I can see the card when I read it on my PC and the file structure seems to be there as expected. This is a 2G card. Any Ideas on what may be the problem? Thanks Quote Link to comment Share on other sites More sharing options...
MVP 2014 Simon Posted March 21, 2012 MVP 2014 Report Share Posted March 21, 2012 What sort of card reader sis you use? There have been problems using built-in readers in laptops, for example. Do you have an alternative plug-in USB card reader that you can try? Also double check that you have the latest version of SD Card Suite, just to rule out any issues with that. Quote Link to comment Share on other sites More sharing options...
PCSControls Posted March 22, 2012 Author Report Share Posted March 22, 2012 The SD CARD is NOT recognized by the V570 controller, I can see it fine in the PC. Quote Link to comment Share on other sites More sharing options...
Ofir Posted March 22, 2012 Report Share Posted March 22, 2012 Hi, If the card is relatively old and probably is formatted to FAT16. Sometimes, in some computers, Windows formatter, which we use in our SD Suite, even when set to format as FAT32, remain the card in FAT16 and even don’t give any sign about the problem. Please try to format the card in other computers, or try the formatter of Panasonic http://panasonic.jp/support/global/cs/sd/download/sd_formatter20.html (After formatting with Panasonic, format again using Unitronics SD card formatter) Make sure that you are using the latest SD Card suite.(Download) Quote Link to comment Share on other sites More sharing options...
PCSControls Posted March 23, 2012 Author Report Share Posted March 23, 2012 I did format with the Panasonic formatter and got the same results, I will try it on another PC to see if that helps. Quote Link to comment Share on other sites More sharing options...
PCSControls Posted March 23, 2012 Author Report Share Posted March 23, 2012 It was a new card but I did take it to another PC and did the WIndows format, followed by the Card Suite Format and then the card into the V570 and it was found and seems to be working... Quote Link to comment Share on other sites More sharing options...
razor_rich Posted May 19, 2012 Report Share Posted May 19, 2012 I also tried the Panasonic formatter (doing all reformatting possibilities) and it didn't work. Tried formatting on two different computers (Windows XP), and it still doesn't work. It's a brand new micro SD card from Best Buy. ugghhh Quote Link to comment Share on other sites More sharing options...
AlexUT Posted May 20, 2012 Report Share Posted May 20, 2012 Hi, Last time a lot of peoples comply at different forums about CD cards of wrong capacity from e-bay and other internet stores. As a first step, I recommend you to check your SD card for real capacity. Simple check will be done by program, which you can download from following link: http://fightflashfraud.wordpress.com/2009/06/18/fake-capacity-32gb-sd-card/ * This link is for information purpose only. I have no responcibility about any side effects. You will use this software at your own rick. If this software indicate wrong capacity - you CD card cannot be used with OPLC, and should be replaced. B.R. Quote Link to comment Share on other sites More sharing options...
