2rlp Posted June 4, 2012 Report Share Posted June 4, 2012 Hi, I have just installed Visilogics 9.4.0. When I run the program I receive a message as attached. Whats the solution to this? Thanks Ron Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted June 4, 2012 Report Share Posted June 4, 2012 Hi, In order to give you the best solution, Please provide us more details as follow: Windows Version Did VisiLogic was worked before properly? if you are using Win Vista/7 please follow the attached file. If VisiLogic opened properly, Go to the properties of VisiLogic and under compatibility ticked verify the Privilege Level “Run this program as an administrator”. VisiLogic & UAC Windows7 Reinstall Instructions.pdf Quote Link to comment Share on other sites More sharing options...
2rlp Posted June 4, 2012 Author Report Share Posted June 4, 2012 Thanks R Moses, my machine runs on Win 7 32 bits. I was previously using Visilogics 9.3.0 for quite some time on this machine. Its only after the upgrade that this has come about. I may have to uninstall it & reinstal V9.3.0 Ron Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted June 4, 2012 Report Share Posted June 4, 2012 Ok Sir, so please try to for the attached doc and i hope it will solve the problem. Quote Link to comment Share on other sites More sharing options...
2rlp Posted June 4, 2012 Author Report Share Posted June 4, 2012 Thank you R Moses, it works now Ron Quote Link to comment Share on other sites More sharing options...
