Gabriel Franco Posted July 26, 2012 Report Share Posted July 26, 2012 Anyone knows a way to connect USB bar code scanner to RS232 serial port of V130 ? I already tried using regular USB-Serial converter, but didn´t work Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted July 28, 2012 MVP 2021 Report Share Posted July 28, 2012 The V130 is not a USB Host, so this won't work. You need to get a barcode scanner with RS232 output. Joe T. Quote Link to comment Share on other sites More sharing options...
