Mare Posted October 13, 2010 Report Share Posted October 13, 2010 How to fix this problem? Thanks Quote Link to comment Share on other sites More sharing options...
R.Mozes Posted October 13, 2010 Report Share Posted October 13, 2010 Hello, Try to uninstall VisiLogic according the steps below>then check for Windows updates>reset your PC>install VisiLogic again. Backup your application files. Uninstall VisiLogic. Erase the “Unitronics†folder from- C:\Program Files Erase the “Unitronics†folder from- C:\Program Files\Common Files If you still facing the same problem, we assume that you don't have MDAC or Jet installed on your computer you can check it here: http://msdn.microsoft.com/en-us/data/aa937730.aspx Please try to install MDAC: http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=78cac895-efc2-4f8e-a9e0-3a1afbd5922e Please install Jet 4.0 Service Pack 8: http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=2deddec4-350e-4cd0-a12a-d7f70a153156 Quote Link to comment Share on other sites More sharing options...
Vidmas30 Posted October 13, 2010 Report Share Posted October 13, 2010 Hi, I had the same problem before: Visilogic was working perfectly, done a lot of programs, but once, when I quit Visilogic and tried to open it again (as I understood) before it had canceled, the same textbox started to show every time I tried to start Visilogic. I tried to reinstall, nothing helped, except one thing: to install it o another directory e.g. on another disc. Hope it helps! Bye! Vidmas Quote Link to comment Share on other sites More sharing options...
Mare Posted October 15, 2010 Author Report Share Posted October 15, 2010 Thanks Mozes,it works.... Quote Link to comment Share on other sites More sharing options...
