lawry Posted September 2, 2012 Report Share Posted September 2, 2012 Hi, Am new to this forum, but have been using Unitronics for quite some time. Need to know if the PLC can generate & print out a barcode based on the information it receives from the loadcell units. Also how do I convert this information into barcode. Thanks Lawry Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted September 2, 2012 MVP 2021 Report Share Posted September 2, 2012 You'll need to use a serial printer with barcode encoding information built in. Google "serial barcode printer" and see what comes up- then download the printer manual and look at the protocol information. You can generate these strings fairly easily with the Unitronics Protocol block. Joe T. Quote Link to comment Share on other sites More sharing options...
