i4 Automation Posted January 10, 2013 Report Share Posted January 10, 2013 We are looking at mounting the V350 outside and need the extra protection of a clear cover/ access door BUT it must be a tight fit due to space restrictions and allow access to the touch screen. Omron have a cover that is ideal for a standard temperature controller but not the shape of the V350 (it’s not square). Any suggestions would be appreciated. Quote Link to comment Share on other sites More sharing options...
MVP 2021 Joe Tauser Posted January 11, 2013 MVP 2021 Report Share Posted January 11, 2013 I use Integra NEMA 4X enclosures with a clear front door and a sliding subpanel for the front-mounted instruments when I want good protection for the controls inside- http://www.integraenclosures.com/ Joe T. Quote Link to comment Share on other sites More sharing options...
Walkerok Posted January 11, 2013 Report Share Posted January 11, 2013 We use the Vynckier covers a lot to get a clear protective cover over operators and screens and they can mount to the outside of any existing panel as long as your component spacing and sizes are will fit inside. You can use these to fit up to a V570, but anything larger than the 5.7" screens will not fit in a Vynckier brand cover. http://vynckierenclosures.thomasnet.com/item/inspection-window-dtcover/apo-transparent-hinged-window-dt-covers/a31-dtcoverlg?&plpver=1005&origin=keyword&by=prod&filter=0 This is just one size and there are more avaialable, but at least you get to the correct website and the general description of the parts. the A31-DTCOVER is 7" x 12" the A41-DTCOVER is 12" x 12" the A51-DTCOVER is 12" x 20" the A61-DTCOVER is 12" x 24" They have both north american and several international standards certifications. Keith Quote Link to comment Share on other sites More sharing options...
