MVP 2021 Flex727 Posted January 11, 2013 MVP 2021 Report Share Posted January 11, 2013 After years of working with Unitronics Vision PLCs, I'm still at a loss to understand the "Trigger" link that is necessary for the ASCII String Variable. The Help files says: "Display String 'Trigger'. When the linked MB turns ON, the string will be displayed." But the linked MB appears to have absolutely no effect. What does this MB do and how should it be handled in the ladder? Quote Link to comment Share on other sites More sharing options...
Emil Posted January 13, 2013 Report Share Posted January 13, 2013 In general, Vision OS is updating the screen. This "refresh" is slower than the scan time. If one wants to see the new string "immediatelly", he can activate on Laddeer this bit and the new string will be displayed at the end of the same scan. As the human eye can difer immages with rate of 0.1 second and usually the refresh rate of display is shorter, it's difficullt to "see" the effect of this bit. It's used very rare, in very specific cases. Quote Link to comment Share on other sites More sharing options...
